ECU Compatability?
One Jay Z
Supra Dupra
Dec 20, 2006
108
SK Canada
Hey, as some of you may know, i recently posted about having a busted fuel pump.. Well that MAY not be the case anymore as my mechanic has instructed me to hold off on purchasing a fuel pump as i may have a bad 1j ecu. Just so i can get myself prepared in case this is the problem, is there any sort of information that i have to know such as repair shops, interchangable ecu's (i.e 1j-2j) etc etc? Can i plug in a tuned ecu into my stock setup? I noticed how there were some tuned ecu's on the f/s section. Also a a/t ecu will not work right? (i would assume so...duh) but you never know!.. LET ME KNOW THANKS!!!
Fletch124
2jz swapped!
Jul 17, 2005
1,282
Reno, Nevada
If your car is auto then you can not use a manual ECU. If i were I would just forget the stock ECU and go for standalone or something similar.
One Jay Z
Supra Dupra
Dec 20, 2006
108
SK Canada
OK so i go to unplug my ecu and check if the capacitators are leaking inside.. Didnt see anything at all, looked fine. Then i go to plug the ecu back in, and now the car wont start at all. At least before it would fire and then die. I am completely lost, without a vehicle and running out of ideas. I dont want to go and replace everything possible as it would be a complete waste of money.. Any suggestions at all .... PLEASE!
OneJoeZee
Retired Post Whore
aboard the Argama
