Ebay intercooler kit, eek.
89Turbo
804
Portland
so i bought the Ebay intercooler kit, the HKS knock off one with piping, BOV and Intercooler(obviously). What i am concerned with is that the intercooler that came with is weee. it is longer and has bigger outlets than stock but the measurments are(core length) 22"x6"x3" long and short. Is this going to negatively affect my turbo or motor in any way or is it still an upgrade from the stock piece??
pimptrizkit
thread killer
Dec 22, 2005
1,572
vancouver Wa
mine has 3 inch inlets out lets, and is 24x12x3 and i run 9-10 psi stock w/ out a boost contorler, and runs hard.. does it have fins on the inside of the ic??
89Turbo
804
Portland
believe so, its at the shop right now....
BosoMKII
497
NorCal
So, is the intercooler's overall volume larger than stock? If yes then it will have a higher cooling capacity.
AGlobalThreat
Acceleration
Apr 4, 2005
991
Santa Clarita
What you bought sounds to be just about half as large as the big ones people buy. 3" thick is good, 22" length is good, 6" tall is kinda short, but I think it'll do just fine.
lol, the way I think of it, is that's like a civic intercooler :p
Some of you will understand
BosoMKII
497
NorCal
He is only running 9psi according to his sig. How much intercooler he needs will depend more on how much boost and what turbo. Too big of an intercooler takes longer to cool off, and contributes to lag.
SC61 MK3
316
FL
yes it should be fine especially if you have the stock turbo. It is more effective and has alot less pressure drop than your stock one. Even though it is not tall its still alot better than the sotck one.
It will also be a much easier install because the tall one you have to remove or modify your front bumper support
AGlobalThreat
Acceleration
Apr 4, 2005
991
Santa Clarita
That thing should be perfect for 9psi. I would think it would be good for quite a bit more too, definetely an improvement over stock, and stock can hold quite a bit.
Boso I found myself staring at your icon longer than it took me to type all this AND think. Weeeird. It's like he's looking at me...
BosoMKII
497
NorCal
HAHAH thats because the little guy is sizing you up. Your next on the hit list. You had best move your cookies someplace safe! The Bunny Mafia will strike when you least expect it.....:evil2:
89Turbo
804
Portland
thanks for al the input people thats what i was looking for, when i uprgrade turbos in the next year im gettin a much larger one so it should be good for now, the most i will run on it is like 12psi
s383mmber1
3,614
Somers New York
Should be fine for 12PSI, jsut curious, were did you get them?
Link? Price?
Thanks,
William
