Easy Fixes for Brother Printer Not Connecting to Computer
potterhagrid007
8
Brother printers are well-known for their print quality, reliability, and easy-to-use features. Whether for home or office, they’re a trusted choice for both wired and wireless printing. However, like any device, sometimes your Brother printer not connecting to computer +1-803-866-1601. This can be frustrating when you urgently need to print important documents.
Click Here to Start a live chat with our support team
If you’re facing this problem, don’t worry — it’s a common issue, and most of the time, it can be fixed with a few simple steps. In this article, we’ll explain the reasons why your Brother printer not connecting to computer +1-803-866-1601 and how you can resolve it quickly.
Why Is My Brother Printer Not Connecting to My Computer?
Before we jump to solutions, it’s helpful to understand what might be causing the connection problem. Here are the most common reasons:
  • Loose or faulty cables (for USB connections)
  • Wi-Fi network issues (for wireless printers)
  • Printer and computer are on different networks
  • Outdated or missing printer drivers
  • Firewall or antivirus blocking the printer connection
  • The printer is offline or in error mode
  • Wrong default printer selected
  • Software conflicts or system errors
Knowing the cause makes it easier to fix the issue effectively.
How to Fix Brother Printer Not Connecting to Computer
Let’s go through easy, step-by-step solutions to help reconnect your Brother printer to your computer.
1. Check Physical Connections (For USB Printers)
If your Brother printer is connected to your computer via a USB cable:
  • Ensure the cable is firmly plugged in at both ends.
  • Try unplugging and reconnecting the USB cable.
  • Use a different USB port on your computer.
  • If possible, test with another USB cable to rule out a faulty one.
A loose or damaged cable is a simple but common cause of connection problems.
2. Confirm Wi-Fi Connection (For Wireless Printers)
If you’re using a wireless Brother printer:
  • Make sure both your printer and computer are connected to the same Wi-Fi network.
  • Check your printer’s control panel to confirm the Wi-Fi signal is strong and it’s connected to the correct network.
  • If needed, use the Wi-Fi Setup Wizard on your printer to reconnect to your network.
  • Restart your Wi-Fi router, printer, and computer to refresh the connection.
3. Update or Reinstall Printer Drivers
Outdated or missing drivers are a common reason why your printer won’t connect to your computer.
To update drivers:
  • Visit the official Brother support website.
  • Enter your printer model.
  • Download and install the latest printer drivers for your operating system.
If problems persist, uninstall the old drivers:
  • Go to Control Panel > Devices and Printers.
  • Right-click your Brother printer and select Remove Device.
  • Reinstall using the new driver you downloaded.
4. Set Brother Printer as Default Printer
Sometimes your computer might try to send print jobs to a different printer.
To set your Brother printer as default:
  • Open Control Panel > Devices and Printers.
  • Right-click your Brother printer.
  • Select Set as Default Printer.
A green checkmark should now appear next to your printer icon.
5. Disable Firewall or Antivirus Temporarily
Your computer’s firewall or antivirus software might block the connection to your printer, especially over Wi-Fi.
  • Temporarily turn off your firewall or antivirus.
  • Try reconnecting your printer to the computer.
  • If it works, add your Brother printer software to the firewall’s allowed list or exceptions.
  • Turn your firewall or antivirus back on after setting the exception.
6. Restart Printer Spooler Service (Windows)
A problem with the Windows print spooler service might prevent your printer from connecting.
To restart it:
  • Press Windows + R, type services.msc, and press Enter.
  • Find Print Spooler in the list.
  • Right-click it and select Restart.
This refreshes the print service and can fix many connection problems.
7. Use Brother Printer Software (iPrint&Scan)
Brother offers free software called iPrint&Scan, which helps manage your printer and scan tasks.
  • Download Brother iPrint&Scan from the Brother support website.
  • Install and open the software.
  • It will detect and connect your printer automatically.
This tool often resolves minor connection problems during setup.
8. Check for Printer Errors
Look at your printer’s display panel or LED indicators for any error messages or warning lights. Common issues include:
  • Paper jams
  • Low or empty ink/toner
  • Offline status
Clear any errors and restart the printer to reset it.
When to Contact Brother Support
If you’ve tried all these solutions and your printer still won’t connect to your computer:
  • Use their troubleshooting tools.
  • Contact Brother customer support for personalized help.
  • If your printer is under warranty, you may be eligible for a repair or replacement.
Tips to Avoid Future Connection Problems
  • Keep your printer drivers updated regularly.
  • Avoid changing your Wi-Fi network name or password without reconnecting your printer.
  • Clean your printer and check cables periodically.
  • Restart your printer, computer, and Wi-Fi router occasionally.
  • Regularly check your printer’s firmware updates via the Brother support site.
Conclusion
A Brother printer won't Connect to computer +1-803-866-1601 is a common but fixable problem. Most issues can be solved by checking cables, ensuring Wi-Fi connections, updating drivers, or adjusting printer settings. By following these simple steps, you can quickly restore the connection and get back to printing without frustration.
