My E brake doesnt work when i pull it it makes noises but it doesnt stop the car from rolling. Are there special brake pads that i must change? and if so how much and where can i get them?
there expensive from toyota and thats the only place to get them. most likely you prolly need to adjust it by taking off the rear wheels and looking threw the hole on the rotor for the adjuster and spinning it till its tight then backing it off 3 clicks.
