Title says it all-Dumped a pint or so directly onto/into wiring harness. Car runs, but there is no O2 feedback like normal, and Vfs never modify, no matter how lean or rich I adjust fuel at AFPR, or with SAFC. Car has 2 operating modes. #1-Start engine. AFRs start and stay high-16.1-16.5. No o2 feedback,VF reads at 0, will run like this for 5 minutes or an hour. #2-2nd or 3rd key hit after starting, 14.5 idle, 13.5 cruise, VF cycles around 2.5, but never goes to 1.25 or 3.75, no 02 feedback. Any suggestions as to which circuit is shorting out in wiring? ECU is throwing no codes, and is not learning at all. ECU has been swapped, and car exhibits same symptoms. TIA, Mike
