driftmotion turbo manifold
MK3.0dudeman
brian L.
Mar 12, 2007
1,628
North Jersey
dose any body have this on there 7M what turbo are you using and is there a way i could not use the waste gate I have and use a external waste gate it's a stock ct26.
I think when I do my rebuild I'm going to be using this manifold I will be going with a big turbo but I'm looking for 350-400hp with a port and palish head and all bolt on's well a lil more than that but no internal work just a stock rebuild.
tell me what you guys think about this manifold thanks.
http://store.driftmotion.com/productdetails.php?sid=146eb003d3d091&product_id_int=276
supraguy@aol
Well-Known Member
Dec 30, 2005
4,253
56
Atlanta
I think that the manifold that you're looking at requires an external wastegate, and you cannot mount a CT26 to it, either. It's a manifold designed for T-4 type turbos.
GotTurbos?
2J = Here; Swap = Near
Apr 24, 2006
951
Dallas, TX
You can not put a ct26 turbo on a t4 manifold. End of story.
Unless you got the stock - t4 adapter and reversed it, but the turbo would not sit in the right place.
Its just a bad idea, so either stay stock manifold and turbo, or upgrade both.
MassSupra89
Almost done.
Nov 3, 2005
1,707
MA
You can achieve 400 pretty easily on a stock exhaust manifold.
Have you looked into turbo's that will bolt to the stock CT flange?
MK3.0dudeman
brian L.
Mar 12, 2007
1,628
North Jersey
why yes i have but I want somthing that flows nicley i have thought about port and palishing my manifold.
