DriftMotion Intercooler: pipes go where?!?
sixtyten6010
25
Metropolis IL
So I got me one of the older style kits from Driftmotion, after a day of pulling out things and moving other things I got the intercooler all mounted up... Then I hit a wall of frustration I can't figure out witch pipe should come out the bottom of the turbo. It seems like I can either get one side all lined up but not the other. so can anyone thats put one in tell me witch one goes where???
I got mine mounted very much like the OP in this thread.
http://www.supramania.com/forums/sh...ots-of-pics&highlight=driftmotion+intercooler
The only 2 pipes I'm sure on where they go are the two on top in the picture here.
So any help to explain the order these would be greatly appreciated.
Thanks.
IndigoMKII
2,181
Madison, Virginia
The s looking one is the pipe that goes in the fender.
The other one, left side second down, connects to the IC on passenger side going to the fender. That one is easiest to put on if you have the front fender well plastics removed.
The pipe you have the reducer on or the other one that is the same pipe but bigger. Use which ever ones fits easier.
