drag tires for mk3
bowtiebuba
stangs hate supras
Sep 1, 2005
207
marion iowa
What kind of tires do you guys run on you mk3, im looking at m/t et street radials, what sizes fit withg out any rubbing?
dbsupra90
toonar
indiucky
those are some wicked tires. as far as what fits w/o rubbing, it really depends on the wheel size, offset and suspension mods. for 16 or 17" rims there are very little options. a 26" tire will fit no worries, 27" tire will fit depending on offset and how low the car sits.
bowtiebuba
stangs hate supras
Sep 1, 2005
207
marion iowa
i want to lower it some day with coil overs most likely and im gonna run it on the stock saw blade, going to sell my borbet rims, i was looking at the 26 cus i do belive duane has the 26 10.5 16 tire omn saw blades
Dec 3, 2003
6,653
Canada
Like bowtiebuba said: > M/T ET Streets 26x10.5 on saw blades :biglaugh:
My car is pretty low also. As a matter of fact, the tires sit under the 1/4 with the slicks on it. Looks cool to :)
Duane
I
itr206
Guest
I havent run them yet, but I have 26x10.5 ET streets on NA MKIV rears.
Ill have coilovers so the adjustment isnt really an issue
I
itr206
Guest
upgradedsupra said:
PS: Life begins at 30 pounds of boost ^^^ ;)
Duane
Im getting there. lol. In a few weeks , Ill change it to 2bar
Bigdough666
Picture Me Rollin
Apr 4, 2005
367
Corpus Christi, TX
slow yota said:
Is this all we can fit under the rear wheels?...Even on a 10 inch weld pro star?
I'd like to fit a 275-50-15 atleast
A 275 is 10.8 inches wide, so youre jus gonna gain .3 of an inch goin with a 275 as opposed to a 10.5.
Now goin to a 315 would be a jump, its about 12.4 inches wide.
BUT, a 10.5, hell, even an 8.5 inch ET Street will hook plenty. Ive seen a Mustang rip the chassis launching on a 26x10.5 ET Street, twisted it like a pretzel so Im sure it hooked well enough.
suprarich
Guest
Nov 9, 2005
2,187
ohio
jester1341 said:
well i have a good idea what to do with my 6 or so extra sawblades
now the next question is where to buy radials?? hmmm
john
I would rather have a 15 inch tire but for the money, a 16 inch hooiser QT pro on stock sawblades works pretty good. But like you said, what are we going to do with all the leftover wheels we have around.
Slow66
I think with my dipstick
Apr 3, 2005
1,457
Newington, CT
Ive tried a couple different combos, and the 26x10.5 on the sawblade is the best for the $$.
The welds don't offer enough backspacing to fit a bigger tire than you can on the sawblades. If Weld offered a 15x8 with 6.5" backspacing, then we'd be in business, but they dont, so a 28x10.5 rubs when she squats. A 26" would probably be ok on the welds, btu at that point, you might as well use the sawblades and save yourself $300.
slow yota
I Wish I Had Lag
Jan 30, 2006
27
South Bend,In.
Did some looking..They also make a 15 x 8 with a 5.5 BS and a 15 x 9 with a 5.5. BS or is 5.5 not enough to tuck the tires under the chassis?
Slow66
Apr 3, 2005
1,457
Newington, CT
5.5 is not enough to maximize tire size. The best would be a 15x8 with 6.5. as i said, i ran the 15x8/5.5, and it fit, but with 28x10.5s they rubbed hard....26x8.5s would fit fine, but then youre sacrificing 2" of section width. Although if your car isnt lowered much, the 26x10.5s might tuck even with the 5.5....its gonna vary from car to car.
And yes, i tubbed my supra :) will be finished in the spring.
EDIT- keep in mind that the tire sizes i use are for the MT ET Streets, different tires are sized differently, such as the MT slicks, in which a 15x10.5 slick is the same width as a 15x12.5 et street, as the slicks are measured by tread width, and the ET streets are measured by section width
dbsupra90
toonar
indiucky
28" tire is a tough fit. 26" or 27" will fit w/o 6.5"
