done with my manifold swap
viper92086
932
NJ
Hey guys i thought i'd show you my new manifold setup. I also tried to make it as clean as possible with the throttle assembly delete mod and i hid the coil backs under the intake manifold
Before:
After:
jmcboost
Missouri
Nice!!!!! Does the upper 7MGTE manifold mate on the lower 7MGE runner, or does the 7MGTE maifold bolt up to the 7MGE head? Looks Great!!!!
ms07s
TORGUE!
Sep 29, 2007
1,083
Memphis,Tn
Very clean! Kinda want to do the same thing with my coil packs but you know changing plug wires is going be a PITA.
viper92086
932
NJ
it does both. the gte manifold is backwards compatible with the ge vice versa. my maifold is actually from a cressida so is the tb and pretty much everything else i used to do the conversion
viper92086
932
NJ
actually it would be pretty easy, and how often do u change the wires... i'll try to get u a pic of how they are mounted
viper92086
932
NJ
AF1JZ said:
Definitely much better looking!!! How's it running these days?
pulls hard now lol, i gotta finish setting up my ebc and then get this thing to the dyno. it should be over 300 rwhp
ms07s
TORGUE!
Sep 29, 2007
1,083
Memphis,Tn
I change my plugs and wires every 20k. Same with trans and coolant flush.
Mr.PFloyd
I am the Super Devil
Jun 22, 2005
3,964
Mississauga, Ontario
then i don't understand why this would be a PITA. 7m's don't reach that mileage anyway :biglaugh:
In all seriousness, bigaaron did the same thing and its easy.
ms07s
TORGUE!
Sep 29, 2007
1,083
Memphis,Tn
I like the idea as the coilpacks are in a bad position from factory anyway. I just want to know how you get the wires in. I also want to see how you mounted the coils. I am seriously thinking about doing the same to mine. Definatly cheeper than an individual coil setup.:naughty:
Dan_Gyoba
Turbo Swapper
Aug 9, 2007
1,836
Alberta
www.gyoba.com
Looks good.
I'd like to move my coil packs at some time. I think that the NA cam covers look better anyhow.
@spoolint78: I like your intake manifold mod, too. It makes so much more sense than having the intake routed back over top of the exhaust manifold.
