Does anyone have some MAFTPRO results??
supralover2000
12.8 and dropping..
Apr 4, 2005
132
Long Island, NY
www.mk3.us
Hello Team,
I'm suffering from Supra withdrawals and having all these goodies (Maftpro, LC-1 wb, .040 over JE's +++) laying around is making it worse. I know malloynx has already shown us how well and reliable the Maftpro is, but todate, no one else has commented on their results with the unit. As you all know, the timing monitor is fully functional, yet it seems no one has used it. I'd like to hear from those of you who have stepped up and made full use of the Maftpro. For as long as we've been tuning our Supras, those of us without a standalone have been tuning blindly when it came to knowing what the ECU was doing with timing. Now that we have a tool that allows us to monitor it, why has no one used it or commented if they have?:nono:
My own reasons are, that my motor is sitting in pieces waiting for good weather and/or a garage to allow us to put it together! THIS COLD NY WEATHER IS NOT SUTABLE FOR OUTSIDE WORK! so for now I can only enjoy Supras vicariously through you all:drool:. So please chime in if you are currently using the MAFTPRO to its fullest pontential.
7M-GTE
ROCK$T@R
Apr 2, 2005
535
KC
I think some more people have... have you done a search for maft pro...
EDIT: I'm running just the maft system and I like it... I wish I would have waited for maft pro...
rakkasan
Currahee!!
Fort Campbell, KY
supralover2000 said:
I guess Malloynx is the only one? too many rookies I guess????:nono:
I'm in the same boat as you. I have MAFT Pro, but it's sitting beside the othe 50 new pieces waiting to go on a new motor. I'm curious as well....
Chris-Supra
Minneapolis/Lakeville, Minnesota
My maftpro is working. I'm waiting on an LC-1 wideband to get it tuned. I will also setup the timing monitor and make some logs I suppose. When I have some free time that is.
So far I'd say im in the mid 400's power wise, untuned on my SP63@18psi. And thats at 10.0:1 AFR's (or even richer, dont know) I'm sure I can clip 500 with a tune and possibly 20psi.
Chris
Chris-Supra
Walbor 255
680cc's
FFI (converted stocker)
Ebay 18x12x3" 3"in/out IC
2.5" IC Pipes
Ebay SS manifold/Ebay 50mm WG
Ebay Tial BOV Knockoff
SP63 .70a/r Coldside -- .81a/r Hotside
And all that ebay stuff is working absolutely flawlessly. So haters stay off my nuts.
tonysupra
224
CT
yea i'm too poor to buy alot of the aftermarket stuff on most websites, forcing me to shop on ebay for parts. I'm always caution about ebay parts because it's inexpensive. Like right now theres a "T04B T04 AR.60 TURBO CHARGER+7MGTE STAINLESS MANIFOLD" selling for less than $500. I don't know how good this turbo is(because i'm a newb when it comes to cars) but i know it's cheap for an upgraded turbo and manifold. i'm glad that the ebay parts are working out for you though.
NJsupraA70
Ex-Supra Owner
Sep 18, 2005
276
NJ
Hello Team,
:wavey:
malloynx
NC
wellington.. i'm running the shit out of the PRO and love it. if you want specifics i can call you or i can give you tons of info on this post
lowbudgettarga
supra and I - Broke
Apr 2, 2005
109
Bellingham, WA
i've been having a blast with mine, the timing monitor is the only thing i'm not using becaue i havn'et looked into setting it up yet, but map, boost control, and afr tracking off of my aem wb.... all working awesome. yesterday we went and did a bunch of 3'rd gear pulls and logged them on the laptop, pulled a little (well, a bunch) of fuel out of the middle of the rpm range and got my afr's consistantly 12:1 throughout, then turned on the afr tracking, car runs soooo good now.
tonysupra
224
CT
Please give tons of infooooo because if the maft pro could save people hundreds of dollars by replacing a boost controller, safc, lexAFM/550 mod, and rise Fuel cut? I def would want to get it. Just got a MHG with studs in and i'm looking at ways to upgrade but i also need results and numbers and support for assurance. I've been doing lots of research on the new maft pro but havent seen many people post up their results.
If yall could, i'd be forever greatful :icon_razz
atlpd3147
kool member
Nov 26, 2005
485
Dacula,GA
callng him is only gonna help him post up here so u can educate all of us in one shot ;)
i was wondering about the boost soleniod that u can use with the maftpro.. anyone using it with an external wastegate? i have a evc iv and wanted to ditch it so i can have everything coming/controlled from the maftpro but the boost soleniod only has two vacuum ports can someone chime in on how to set it up with an external wastegate?
tonysupra
224
CT
i mean, should the maft pro be run with 550cc injectors or is the stock injectors ok?
dbsupra90
toonar
indiucky
im not sure i follow. all you need is 2 ports. 1 in and 1 out. from there you just need to setup the lines properly on the gate.
atlpd3147
kool member
Nov 26, 2005
485
Dacula,GA
well the calling him part should be clear.. i think he sould reply on the forums so all of us can learn something new. and as far as the boost seloniod my evc iv had 3 ports and the maftpro seloniod has two.. dr jones had linked me a diagram on how to set up the vacuum lines. sort of.. seems like i have to tee one of the vacuum ports with a vacuum source and one of the ports from the wastegate.. or something like that.. :biglaugh:
