Differential Oil Drain/fill Socket Size?
Titanium
FL
Tried searching and looking on the service manual but no luck. Wanted to know so I could bring the right tools to a shop.
Thanks.
te72
Classifieds Moderator
6,624
9
WHYoming
24mm, and for the love of all that is holy, remove the FILL bolt first. Why, you ask? Well, if you drain all your fluid out of your diff and find out that your fill bolt is quite stuck... ;)
Also, helps to use a 6 point socket for this job.
