Diff Swap
te72
Classifieds Moderator
6,611
7
WHYoming
The only "benefit" to swapping in a Mk4 diff over the stock one would be lower rear gearing, so depending on what you're trying to achieve, you might be over-thinking it. I wouldn't mind a slightly lower gear for highway cruising, but I don't do enough of it to really put any effort into it.
Why do you ask though? What purpose are you getting at? :)
Jake_ak_cent
52
Utah
The stock MK3 diff's gearing is too high too work with a V160, so I was trying to figure out the easiest way to bring the gearing down in the diff so it would be more compatible. And thats how I ended up at diff swap. So Im trying to figure out if I can do an internal swap, or if I'm looking at a whole diff unit swap.
te72
6,611
7
WHYoming
I'd look into R&P swaps before I'd go to the headache of an entire diff swap. Might look into Truetrac, Kaaz, etc as an aftermarket replacement, or Jaws Gear.
