dash Light problem on my brothers car
Mr.PFloyd
I am the Super Devil
Jun 22, 2005
3,964
Mississauga, Ontario
well it was right after the deck install in my brothers car. The cd player light AND the clock wont turn off (the stock clock) everything else turns off as its supposed to, its just those 2 don't go off. any ideas on this? I am no wiz at all on electrical and the deck was installed by a friend, so i still have to check up that wiring (i posted a bit back and asked for wire colors and told him) but any ideas where to start or what could e the problem? is it maybe just a bad ground somewhere? Any help is appreciated guys.
CRE
7M-GE + MAFT Pro + T = :D
Oct 24, 2005
3,485
Denver, CO
Have you made sure the ignition cylinder is turning all the way to the off position?
It may be the ignition switch as the Acc position powers 15A Cig. and 7.5A Radio. Test those when the ignition is switched to the off position.
If it's not the ignition switch: Since the clock only has 4 wires running to it I'd start next there. One is a constant ground, then there are 3 12v lines: 15A Cig., 20A Dome, 15A Tail.
Clock and Cig:
http://www.cygnusx1.net/Supra/Library/TEWD/MK3/manual.aspx?Section=Main&Page=128
Taillight and Illum:
http://www.cygnusx1.net/Supra/Library/TEWD/MK3/manual.aspx?Section=Main&Page=062
Ignition Switch:
http://www.cygnusx1.net/Supra/Library/TEWD/MK3/manual.aspx?Section=Main&Page=036
CRE
Oct 24, 2005
3,485
Denver, CO
Figit090 said:
thanks CRE, i will probably need those when i try to figure out why my clock doesn't work, nor the keyhole light.
Regarding the keyhole light: Does the ring around the ignition cylinder light up when you get in the car? If so check the switch attached to the driver's side handle. Set your dome light so it comes on when the door is open. Close the door and lock the car. Pull up on the driver's side handle. If the dome light comes on it's probably the LED.
Courtesy Lighting:
http://www.cygnusx1.net/Supra/Library/TEWD/MK3/manual.aspx?Section=Main&Page=68
p5150
ASE and FAA A&P Certified
Central Idaho
I think you may have accidently used one of the illumination wires as a power source wire. Or, you may have used the incorrect wire as ground and broken the circuit for one of the illumination relays.
Some of those circuits will give you a +12 or ground indication with a voltmeter but it doesnt necessarially mean that it is always dedicated to that function.
I think you will find your answer here:
Play with components to test your circuit if the color doesnt give it away (open/close door, etc)
