damaged injector question
83restomod
Bryan
Feb 11, 2008
100
clinton NJ
can injectors be damaged due to a starvation of fuel?
say u had an incorrect micron fuel filter before your fuel pump the pump was screaming loud trying to work hard to get the fuel past this dumb filter, engine ran but very poorly (really lean obviously). could this cause pre-mature injector failure?
Injectors do not like to be dry run.
Why would you run a super thin micron fuel screen? What did you replace it with? Why would you?
What was the first problem?
What is the problem now?
