ct26 57 trim question
rocktownmkIII
rockford il
I was wondering if it would be safe to run a ct26 57 trim on stock fuel with just full 3 in exhaust intake and mbc. Ive searched and ive read a lot of conflicitng answers some people say its fine because i will hit fuel cut so i dont run lean and i can lower the boost. Also, will i hit fuel cut earlier with and upgraded turbo? I was just wondering because i can hear my turbo dying and if i get it rebuilt i figured its almost the same price to get it upgraded. thanks for the replies everyone
rumptis
나는 제프가 당신을 사랑
Aug 16, 2005
814
North Vernon, IN
Short answer is:
Yes it will be ok on the stock fuel system.
Yes you will hit fuel cut earlier cause you will be flowing more air at the same boost level.
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
Another thread like this??
Do any of you use the search function on this site? It still works, right? We're not turning into SF in that respect are we?
::Edit, yes it does work...
Push
Cressida
Aug 28, 2005
151
Naperville, IL
look at his previous posts.... all he ever talks about is this... but doesn't search...
rocktownmkIII
rockford il
starscream5000;994409 said:
Indeed, you are correct :)
not really true look at how much time i logged on here and you can see i search a lot. I read a lot of conflicitng advice on many things and want to make sure im getting realiable and credible advice not just someones opinion
