Ct-26 dimensions needed?
sthmstr
219
Colorado
Just curious if anyone can give me dimensions of the exhaust inlet for the CT-26? (Specifically between the bolt holes) Really appreciate it.
gofastgeorge
944
Texas
Turbo bolt pattern - W x H
T3 ---------- 86mm x 45mm
T4 ----------- 83mm x 70mm
CT26 -------- 70mm x 80mm
Nissan T25 73mm x 40mm
TD006--------3-bolt - 65mm C. to C.
TD08 down pipe 4.1" square x 3/8" thick.
3" ID center hole
4 - .415 bolt holes (10mm plus clearance) on a 4.185" B.C. (square pattern).
K24-26 ---------- 76mm x 38mm
K27/28 ---------- 86mm x 44.5mm
Apex ---------- 73mm x 33.5mm
sthmstr
219
Colorado
Wow. Thanks so much for gettin back to me. I kinda got involved in my other project and forgot to check back on this one. Super sorry for not thanking you long ago. I was wondering because I was toying around withthe idea of making an adapter flange to bolt up a 20g instead of the CT26. Looks like the dimensions are such that it could work well. Thanks again!
3" ID center hole
figgie
Twin Cities, Minnesot-ah
Greddy does this in their TD0620g kit ;)
