CT-26 Burns Oil when revved
AjWit
Boostin without Boost.
Jan 31, 2009
92
Pittsburgh, PA
Thanks to anyone that helped with my last problem.
Now, my cars idle has gotten better and it seems to run ok now. If you don't know, i just did my BHG job and i'm almost 100% A-OK. I tried driving it today around the block and it has little power past 2500 rpms. Once i hit 3500 i shifted to second because it was so weak. I have a 3" dp to atmosphere now so its super loud.
My problem is this, when i rev the engine while parked, i hear a swirling of air sound(i'm guessing is the turbo spool through the open dp). I also have a little white smoke that gets kicked out of the dp as well. I mean, it will only do it when i rev it up to the point of spooling. I have a bad gasket seal on the oil line connecting the turbo, could this cause the burnt oil or should i replace the turbo because it's going bad? Wanted someone's expertise on this. Thank you.
