Ok so i just rebuilt my 7mgte over xmas break. The car is and 88 with the cruse control but its not working after the build. it worked perfect befor the build but now when i am on the hiway and try to turn on the CC from the steering wheel the little green led indicator on the switch cluster blinks on and off over and over. What is going on! I checked all hoses and wires to CC under the hood and all is fine. I cant figure it out. Is there a CC fuse or some reset thing?
And also the car has TEMS and the issue is this. i have wired a switch to the inside of the car which is wired to the diognostices thing up front. All it does i jump the two terminals to swich the stiffest setting on or off. This works fine when the car is off, i can flip the switch on and off with tems going from medium to stiffest. But as soon as i start the car it jumps back to medium setting and the switch then does not affect the tems. And again this was already wired befor my rebuild and worked fine. Could these two things be related? It is very frustrating and i cannot figure out the problem! Any ideas would be appreciated. Thanks
