Cruise control delete - vacuum hose pics?
iwannadie
981
gilbert, az
Ok, Im having a hard time with a vacuum leak and cant seem to track it down.
When I did my BHG I pulled the cruise control while I was at it. Now I have A vac leak Im thinking its with the cruise gone and I didnt route it all back correctly.
So, can someone post a quick picture of that area and the vac lines you rerouted or capped off? Or even pics With the cruise and just tell me how/where to cap/route.
I have the vacuum diagram and it all seems correct to me. However, i can hear the vacuum leak, just cant see or feel it anywhere. Also I have no clue if my rerouting job is correct ha.
Oh, also on my diagrams it doesn show a vacuum point on the back of the intake. Its right below the brake booster vacuum line, what goes there?
Alan
82
Gulfport, Mississippi, United States
A quick way to find a vacuum leak is to use carb cleaner and spray it around any parts that have to do with a vacuum. You will know when you find it the rpms will eather go up or down depending on the severity of the leak.
iwannadie
981
gilbert, az
Ya, I was hoping to avoid spraying junk all over my motor ha. I think ill go buy a vacuum gauge and then go from there.
