cross your fingers!
suprabones
73
Cleveland Ohio
Well, I have been putting this motor swap together for awhile now... It has long been due... my car has been sitting for like 3 years :3d_frown: I finally bought a jdm na 7mge motor to take the place of my old turbo motor.. I know this is a no no, however I really cant afford to buy a whole new turbo motor at the moment, so I am just going NA-T. Everyone cross there fingers that this bad boy starts up. I think I did everything that is needed for this swap to work. if anyone see's anything I need to do before I drop the motor in, please say so. JDM 7mge, swapped oil pans, new oil pump, motor mounts, USDM oil pressure sending unit, ARP headstuds, HKS 1.2mm HG, CPS, Coilpack, turbo AFM, new plug wires, NGK plugs, 3 wire 02 sensor, rewired 2 knock sensors into 1 for ECU, changed the entire harness to turbo harness, new timing belt, new serpentine belts, AC removal, cruise control removal, CC removal, set timing to 0 on crank, cams, and CPS. am I missing anything? This baby should crank up hunh? any help would be awesome. Thanks in advance :naughty:
