Crank, Fuel, No spark
NYsBlueMA
Evo+supra=3 cars
Sep 24, 2009
136
New York, New York, United States
I was so happy when I got my harness back from the shop that I ran over to the shop and started wiring her up after everything was put together I crank and wait for that magical moment....NOTHING....I checked and saw I have fuel, no air restriction spark plugs are soaked in gas I read that if the ignitor is not bolted down it wont ground or the ignition fuse blew (I'll feel so stupid if that's it). Also my engine bay is a mess what did you take out/put in its place? some pics would help too :3d_frown:
JonoTurbo
Going for broke
CT
While i'm pretty sure the 7m igniter grounds through the bracket, the 1jz one doesn't seem to do that. I've had one hooked up hanging free and the car still ran.
Check your codes. Make sure your crank position sensor is hooked up.
JonoTurbo
Going for broke
CT
The crank sensor plug is right near the alternator. It's a two wire plug, the sensor itself is in the side of the block on the passenger side right behind the crank pulley.
