Crank Angle sensor
dtaylor3
myrtle beach
Did a check and realized i had no power going to my crank angle sensor. Just wondering where does it wire into? I have a soarer 1jz automatic engine with stock ecu
You won't have power to the wire. A voltage is generated every time the wheel passes by the sensor.
You can check the resistance of the sensor and the wire but the best method to check a cam or crank sensor is with a oscilliscope.
toyotanos
What will we break today?
2,844
Coon Rapids, MN
Same answer- using an oscilloscope. Lots of signals are too fast for any ordinary meter to pick up on, which is why scopes exist. Now the fun part is determining what is a good and bad signal.
