cooling fiasco
F_T_F
C2H5OH
Nov 12, 2006
255
fort fun, colorado
another day another problem. heres the story. blew the hg 3 months ago. replaced that, has the heads resurfaced and checked for cracks. every thing was ok. put in an HKS 1.2mm head gasket with ARP head studs torqued to 80 ft/lbs with moly lube. got the car back together worked fine for a week then started overheating which turned out ot be the water pump. so threw in a new one. started driving today and was just driving to make sure every things in working order and i started to steam. the wierd thing was that the car wasn't overheating just steaming from the radiator cap and from the overflow tank. im going to replace the radiator cap cuz thats probably fried by could this cause me to steam from teh overflow tank or is there another problem behind this?
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
If steam is coming out of the rad cap, then it's quite possible that steam can come out of the overflow also since the vacume assisted hose to the resivoir is right under the rad cap ;). Replace and report back...
F_T_F
C2H5OH
Nov 12, 2006
255
fort fun, colorado
well its just steaming but i can here the fluid in the overflow taknk bubbling but i think thats just becaus of the pressure difference. my main concern is that it theres a clog in the radiator but i would imigian if that were the case i would see a temputure difference
IHI-RHC7
"The Boss"
Oregon
Replace the cap and report back. Also, I'd HIGHLY recommend retorquing the head if it has gotten hot at all since the MHG was installed.
F_T_F
C2H5OH
Nov 12, 2006
255
fort fun, colorado
put the cap on and it started overheating. i did a check on the thermostat and it wasn't opeaning. that seems to have fixed the problem for now. i wouls also like to say that tommyknockers beer brewed rite here in good ol colorado is the best!
F_T_F
C2H5OH
Nov 12, 2006
255
fort fun, colorado
yea it was the thermosta got it back in and went and dynoed it. 280hp at the wheels on a bone stock engine. i was rather suprised. has this problem happened to anyone else. replacing the HG and things all failing one after another. i mean at first it was the water pump, then teh radiator cap and thermostat
F_T_F
C2H5OH
Nov 12, 2006
255
fort fun, colorado
yea pretty much bone stock re built teh enging 5000k ago.
hks SSQ blow off valve
MAP-ECU
and a few autometer guages for boost, egt, and oil temp oh and a turbo timer. but yea thats it.
ill see if i cant hunt down the dyno and post it.
