Coolant temp sensor thread size??
peteyturbo
59
Philadelphia
I need to install a coolant temp gauge since I am fed up with trying to get the stock gauge to work. Does anyone know the thread size of the coolant temp sensor for the gauge?? I know there are I think 3 different coolant temp sensors on the tstat housing, but the one I need to know is for the gauge only..
Obsessionw/Boost
198
Albany, NY
Im confused.. where you labeled your radiator cooling fan sensor switch, i thought that was the coolant temp. sensor....
The plug is broken off of that sensor on my car, can you tell me how many wires are by that connector?
Thanks
peteyturbo
59
Philadelphia
There are two wires going into that connector..
Thanks
figgie
Twin Cities, Minnesot-ah
http://i32.photobucket.com/albums/d43/awd4dr/supra/ThermostatHousing.jpg
you are in luck.....
1/4 BSPT!!
Not to be confused with 1/4 NPT!!!
basically the diff is one thread per inch(1/4"-28 NPT v 1/4"-29 BSPT) ie you try to force it you WILL cross thread it!
peteyturbo
59
Philadelphia
Thanks figgie!! I looked far and wide and could not find that adapter to use with an auto meter gauge..I just ended up buying a rad hose adapter with a 3/8 npt fitting to use with the supplied hardware, ended up gettin a boos gauge too..Thanks for the help!!
1/4 BSPT!!
Mr.PFloyd
I am the Super Devil
Jun 22, 2005
3,964
Mississauga, Ontario
yep hes right. mine is 1/2 BSPT.
On the topic of threads, does anyone know if a 1/8 NPT will work for our oil pressure gauges? and if not anyone know of a place to buy an adapter?
Justin
Speakers?
Spokane, Wa
1/4 BSPT!!
Arn't you the one that said you crossthreaded yours and it ended up fine?
http://store.summitracing.com/partdetail.asp?autofilter=1&part=ATM-2269&N=700+115&autoview=sku
Justin
Speakers?
Spokane, Wa
CryoSlash said:
so i need 1/8 BSPT?
Yep, that adapter i linked to. Its what I used on mine.
figgie said:
heavens no not me.. that was Johnny Dangerously.
Oops, my apologies :)
What did you do for your water temp gauge? I could not find the correct thread pitch.....
