Coolant leak problem!!
boosted yota
lurker
Jan 16, 2008
Rockford, IL
Hi guys Im not sure if anyone else has had a similar problem. But if you guys could give me some good tips I would greatly appreciate it. My Coolant leak is coming from the gasket of the long coolant tube that runs along the side of the block. This has been my third time replacing it and the thing still keeps on leaking while under operating temp. I have honestly replaced almost every part of the cooling system so im not sure why the gasket is still leaking.
Ya both surfaces need to be clean and dry and then install it.
Unless the pipe is cracked which isn't unheard of doesn't happen very often. Also it would prolly leak all the time if it was cracked.
