Coolant issue
917mgte
115
butte mt
i just changed the coolant hoses that run from the block to the isc valve to the throttle body and back into the block and now im getting coolant through the exhaust i was wondering if there is any way that coolant might by getting in through the intake manifold.
89supra7mgte
797
colorado
on the bottom side towards the front of the lower intake there is a coolant passage. Make sure you dont have a crack in the tb, or a leak from that lower intake area. Are you sure its coolant and not just condensation?
