car: 89 7mgte stopper head gasket, 550's afpr, walbro, lex afm, sp61gt on stock waste gate (14 psi). afpr gauge liquid filled, no 12v mod
when i jump the fuel pump from the diagnostic box, it reads 50 psi, at idle its reading 38psi wit vac on/ 44 psi vac off, my vf values are a flat 5v at 35psi vac on and hit 3.5v at 38psi vac on. seems like i have a lot of fuel so how come im still lean at idle? afm screw is about half way out and i can only get the fuel pressure up to about 43 psi or so with vac on and STILL at 3.5v.
intentions: getting the vf's to stock 2.5 or 2.25 at idle. what am i overlooking? only thing i can think of is the fact that the fuel pump is NOT at 12v at idle which might help or solve my issue should i do the mod.
