coil pack mounting
viper92086
932
NJ
hey guys, i'm working on my na-t conversion and was wondering how those of you mount the coilpacks to your valve cover? should i drill a hole and ust a bolt and screw or just jbweld a custom bracket to the top of the cover? thanks
bowsercake
828
Irvine, Ca
You could use a custom bracket. You could also pick up some GTE valve covers here or at a junkyard for cheap. I've seen a custom bracket that mounted it in the rear, looked pretty good.
viper92086
932
NJ
no to the gte valve covers, i guess what i really wanted to ask is what is the best method of mounting a bracket? drilling holes or jbweld, what i'm afraid of is if i use a nut/bolt combo the valves won't have their clearance
