codes 31 and 34... HELP PLS! :'(
solardrgn
77
socal
last night while driving my car couldnt go past 2100 rpms and i had to just shift at 2 every gear. i checked my car and it gave me codes 31 and 34. im a noob so i dunno where to start... any help and tips appreciated. thanks
8,897
31 is the airflow meter signal. It means you are not getting the Hz signal in its voltage range. 34 means the airflow meter is showing way to high of a frequency signal. Clear them and recheck.
91Supra313
1,062
Clarksville TN
Also if that doesn't work ( clearing them ) then check the connector. I had that issue with mine a few times and it turned out that the connector was not snapped in all the way.
