code 52 knock sensor
blue_supra_boy2
27
California
bought a knock sensor but the bolt was alot smaller than the one on the engine
also the broken knock sensor said 76 on the bolt and the used one i bought said 75 ccould that be the reason im still having code 52
thanks,
Bryan
Devin LeBlanc
1,830
Las Vegas NV.
Check with a ohm meter the two knock sensor's wires to see if they are shorted to ground or shorted to positive with the harness unplugged from the ECU, If not then check continuity between the plug on the ECU and each knock sensor wire.. If all checks good then replace knock sensors.. Let me know if you need one I have some
Thanks
