code 51/ car tries to fire
Xtreme
138
Lebanon, OR
just put my supra back together, got a code 12, 22 and 51. fixed the 12 and 22, and now I cant fix the 51. My car wont start, it just cranks over and sputters and pops out the exhaust. Every once in a while I smell gasoline. I checked the connecter on the tps, unplugged and plugged it back in several times, nothing. please help if you can thanx
I also would like to know which plug wires goto which coil pack, Ive timed it again and again (set cams straight up and crank at 0 deg, I am unsure where the cps goes into the block, I know to line up the notch with the hole in the shaft, but I could be a tooth off)
