code 24
thebuddrik
149
Lafayette ,La.
ok guys, i am beat down. i have been at it all day, i guess i am not a fast mechanic. i have been reassembaling my car from having my head rebuilt. as of now i am getting a code 24 and a 31. the car is bone stock with a cometic headgasket and arps. i am also getting a vacume leak, it is loud and squeels. i have looked and cant find it. i pressured tested my intake and cant hear it. what and where is a Intake air Temp Sensor Signal? i dont know why i am getting an o2 code. any answers will be apreicated.
thank you
8,900
I think those are airflow meter codes. I would have to get my book out. It has to be plugged in to work right.
There is no hurry, don't be fast. Do it right.
The temp sensor is inside the airflow meter. Belts aren't adjusted right. You might have an exhaust manifold leak, depending on what you mean by loud. Put a vacuum gauge on it to see if you really have a leak.
jetjock
creepy-ass cracka
Jul 11, 2005
9,439
Fast mechanics are usually bad mechanics. I try and work on my car like it's a watch...or an airplane.
You don't have an O2 code. The codes you do have are associated with the AFM. The temp sensor is integral to it. It's that little probe sticking down inside. Since both sensors are completely independent of each other and the odds of them failing together slim it appears you have a wiring problem associated with the AFM or a loss of 5 volts going to it. Either that or you've left it unplugged. Both are easy enough to check.
edit: beaten by Nick ;)
thebuddrik
149
Lafayette ,La.
thanks guys, i was getting on here to edit the o2 crap that i had put ( earlier i had a 21 and i guess that i had them mixed up) i think i narowed down the vac leak. i sprayed carb cleaner on part of the manafold and it made the car bog down. that sucks, all of the gaskets are new.
thebuddrik
149
Lafayette ,La.
i am such a jack ass! i forgot to plug the afm back in after i had tried to pressure test it. now i am getting a damn 51!! i hate the 51! when I had the throttle body off i set it perfect as per the tsrm.
i spraied it on the front corner of the gasket betwen the bottom runner and the main manafold.
thanks
jdub
Feb 10, 2006
10,730
Valley of the Sun
If your AC button is pressed, it will always set a code 51...might want to check.
thebuddrik
149
Lafayette ,La.
I pressed the AC button whenever I saw it. Last time I tried to adjust it using the TSRM it didn't work so this time I did it on a bench, with a good meter.
Going to bed now, I will fix that leak tomorrow.
thanks guys
SupraMaster
Pure Street Racing
Mar 24, 2008
204
Washington
www.facebook.com
Code 24: IAT sensor circuit. Cause: Intake Air Temperature sensor or circuit, ECU
Code 31: VAF sensor circuit. Cause: Vane Air Flow circuit, ECU
Code 51: A/C switch ON during code retrieval. or Closed throttle position switch OFF during retrieval. or Park/ Neutral position switch not in P or N during code retrieval.
Cause: Throttle position switch or circuit, ECU, or Park/ Neutral switch, start switch.
jdub
Feb 10, 2006
10,730
Valley of the Sun
Code 31 on the 7M-GTE: Open or short circuit in air flow meter signal.
Trouble Area: Air flow meter circuit, Air flow meter, ECU
What you posted applies to the 7M-GE
Code 51 refers to no IDL signal with the TB closed...as I said, having the AC button pressed in sets the code.
Trouble areas: A/C switch circuit, A/C switch, A/C amplifier, Throttle position sensor circuit, Throttle position sensor, ECU
The TRSM spells this out.
