code 14?
tyler
74
canada
i ran my cel and got code 14.. what is this code mean and how would i go about finding/fixing the problem
Tyler
Rich
tunin' tha beast
Jun 2, 2007
319
the netherlands
Code 14 is ignition:
'No IGF signal to ECM (=ECU) for 4-7 consecutive IGT signals (=ignition signal) with engine speed less than 3000rpm.'
Can be:
- Open or short in IGF (ignition confirmation signal) circuit from igniter to ECM
- Igniter
- ECM (=ECU)
Check the TSRM page EG-519 and further for diagnostic procedures.
I'd say most probably a broken wire or loose connection, measure the ohms between the igniter and the ecu, should all be close to zero.
Supratrbox2
Damnit
Jul 27, 2005
133
South Jerzey
My blitz ecu threw this code then took a shit. So be aware that that could also be your problem. I replaced over $550 in parts then realized it was the ecu.:aigo:
