As it sits right now, the car will start for a couple seconds and runs perfectly and then cuts right out. I can repeat this over and over. Check the codes and 14 comes back everytime I try something.
First I checked the coils and they each measure .4 ohms, each connector has 12 volts at terminal one and infinite resistance between each coil and ground. (checked with a fluke dmm so I think these reading are accurate)
Next, I checked the igniter and verified continuity in the wires up to the coil pack. Rather than test the igniter fully, I borrowed a known working one with no luck. I reinstalled mine and ran a ground wire from the case to the body ground.
Next I checked the cps. All measurements were ~160ohms. I checked these readings at the ecu and they were identical. I checked the clearances per the TSRM and they all checked good as well. I heard so many talk about the connector so I went ahead and rewired the cps.
I have had the car since January and have driven it approximately 200 miles. I was trying to find a coolant leak and after replacing a missing clamp, I started the car and let it run for 15-20 minutes. I shut it off and went in for the night. I came out 2 days later and it wouldn't start and threw code 14.
Since I have gotten it, the only other code I have got was 11. After I got this code, I went home and noticed that the previous owner had just shoved one of the ground wires into a slot in the fender. I moved it to a bolt and thought that fixed it. During one of my attempts at fixing this problem, code 11 did come up once. I am not sure if this was a fluke or if it is related but the code hasn't came back.
As for grounds I have two seperate ring terminals bolted under the intake manifold with about 7 wires going to them. Does this sound like the correct number?
This problem is driving me crazy and I don't know what to check next. Any help would be greatly appreciated.
