clutch question
DSGsupra89
http://www.highgearlife.c
Jun 8, 2007
116
West Melbourne Fl
Ok I need an new clutch I'm thinking of geting an hole set for my r154 but I was woundering. If the clutch wen't out is it an good Idea to just buy an new clutch and just use the same presure plate then getting the whole set just wounder.
pressure plate takes just as much of a beating as the flywheel...
if you're flywheel isn't toast, get it resurfaced, and get a new clutch (including the PP).
What are your power goals, and what power are you at now?
AJ'S 88NA
2,419
Florida
I'd say the PP takes more punishment than the flywheel. Always replace the PP with the disk, the PP has springs that get weak with use and like poodles said it's a good idea to have the flywheel turned and clean up so the new clutch will break in properly.
james_9876
Rehabilitation time...
Aug 1, 2007
183
Spartanburg, SC
Just get the whole set... it's usually cheaper. Like everybody said.. Pressure plate wears out because it's a spring, resurface the flywheel cause the flywheel surface and the clutch wear into each other (think disk brakes), and the throwout bearing could always be replaced.
One thing though, if you take out the flywheel go ahead and invest in a REAR MAIN SEAL. It'll save you in the long run.
Quick question though, are you gonna pull the motor and trans or just drop the transmission?? Just curious. :biglaugh:
tranny is easy to drop if you have the right tools...
I highly recommend the Action Stage 3 clutch I got from driftmotion though... been 2 days driving on it and it's breaking in nicely and it's very tame for a 6 puck clutch...
86_sports_1jz
slow 700hp build...
Aug 27, 2006
1,217
OK
like everybody says replace the clutch and presure plate, if you have money get a light weight flywheel otherwise resurface the stock one but for sure if your rear main seal is old replace it. i recommend you get a 6 puck clutch that's sprung
DSGsupra89
Jun 8, 2007
116
West Melbourne Fl
Thanks everybody I was thinking of getting an stage 3 clutch any way. Im taking the tranny out I know how I done it before. I invest on the rear main seal were can I find one the rear main seals by the way.
