Clip in brake hardware kit
GetBoost
76
Fayetteville
I just put new rear rotors on and brake pads. The clips were still good so I reused them. How important is the thin metal plate that goes on the back side of each pad and between the caliper. It doesnt really clip on, it just sits there I think. Does it help put even pressure on the pads or something? The brakes fit fine without them I just want to make sure before I drive it.
Clip
The Magnificent Seven
Oct 16, 2005
2,738
9
Virginia
use some disc brake quiet from crc to stick them to the pads. far as i know its just a backing plate that allows the piston to push against it instead of the actual brake pad
GetBoost
76
Fayetteville
thats what I thought also. I ended up puting it together without the plates because the ones I have were kind of rusted. Anyone know if this will cause any problems?
GetBoost
76
Fayetteville
okay well I have no squealing so far. I went to get new ones, but they were not in any of the brake hardware kits (from advance, auto zone, and napa). I wonder if I can get just the anti squeal plate from toyota.
Clip
Oct 16, 2005
2,738
9
Virginia
i suppose the squealing would be caused by high-speed vibration of the pad/like a chattering, except faster. the metal would give this vibration something to bounce back against and control it, or the stuff that holds the metal to the pad would absorb the vibration (and ultimately noise). just speculation, but i'd guess thats how the disc brake quiet goo works.
Oct 11, 2005
3,822
26
Thousand Oaks, CA
There are actually two plates. The silver metal shim, and a black plate with a slick (moly?) coating. The silver plate just provides a smooth surface for the black plate to contact. If you look at the pad itself, the backing plate is painted and pretty rough so the black plate would bind against it and not slide as desired.
So, if you don't have both plates, then adding or removing just the silver one won't make much difference.
You can buy the shim kit separately from Toyota. front shim kit 04945-24010 $28
madsupra88
BoOoOoST
Sep 17, 2005
1,245
Detroit,MI
It does even the pressure out when brakes are applied, the hot spots is what really causes the squeeling. and ofcourse the brake pad being thin will cause squeeling also, so that plate actually thickins the pads in the back, so makes it look like to were its not as thin and at the point of squeeling time. lol i unno if anyone understood that. but yea
C.44
164
Behind the keyboard...
Indeed i thought those were to pull them off. Ofcourse rust is going to hinder that in due time but ok, the anti squeal plates have some sort of dampening coat to take away any leftover vibrations.
Asterix
Lurker of Power
Vienna, VA
None of that stuff is necessary. Has anyone seen those wishbone springs on other cars? I've run without any shims for years with no problems. The piston can ride just fine directly on the pad. Squeal is far more dependent on pad material than anything else. The shims and goo are just insurance so people won't come back to the shop and complain. If you don't have them and don't want to buy them, don't worry about it.
Asterix
8,899
Squeal and squeaks are two different things. Have you ever seen Chevy's that last as long as Toyotas. No. Sometimes one will last, but in general, they don't. So saying another manufacturer doesn't do something doesn't mean you don't have too, or it doesn't matter. Toyota is a very thourough manufacturer.
Dragging the pad on the rotor makes a light glaze over time.
But pad composition and rotor do heavily influence break squeal.
