In the TSRM, it specifically states NOT to use water to clean the evaporator http://www.cygnusx1.net/Supra/Library/TSRM/MK3/manual.aspx?S=AC&P=33
Can someone tell me why it would be a bad idea to do this? As long as you have the refrigerant port and suction port capped, and make sure not to get water INSIDE the evaporator, why couldn't you say, soak the whole thing in hot soap and water? My evaporator is disgustingly filthy. I used a commercially available foaming solvent ( http://www.grainger.com/Grainger/ww...ch&Ntt=2rzw3&N=0&GlobalSearch=true&sst=subset ) but there is STILL crap inside it.
Also, has anyone tried to mock up a cabin filter for our HVAC system?
Thanks for any help!
