I changed the sparkplugs and finaly got it to idle right and now when i drive it just randomly cuts.
When i stop at a light usually idles good but lets say 1/10 outta each light i stop at it will just shut off once i hit the gas....
is this related to the code and were to i start to try and fix this....
ECU(+B)
Diagnosis
•Momentary interruption in power supply to ECU.
Trouble Area
•Ignition switch circuit
•Ignition switch
•Main relay circuit
•Main relay
•ECU
ECU(+B)
Diagnosis
Trouble Area
•Ignition switch
•Main relay circuit
•Main relay
•ECU
