cheapish tripple plate clutches
williamb82
909
4
Tampa, Fl.
i searched and found that tilton makes clutch discs for their 7.25in multiplate clutches with a 29mm 21 spline hub which is what fits the w58 and r154. also quartermaster will make the flywheel for the 7m for $270ish. used tilton tripple plate clutches got for less then $150 shipped on ebay and new are ~$500. however yous want the cermatalic discs to try to street the clutch, though id recomend organic or kevlar if possible. i havent checked other mfg's for the discs. just thought id throw this info out there. makes for a cheap high hp capable clutch though will require an internal slave setup which isnt too much. depends what brand you go with.
williamb82
909
4
Tampa, Fl.
figured id post it as im going tripple on my t56 and keep getting asked do they make discs for the r154 since my tripple clutch was so cheap. lol
williamb82
909
4
Tampa, Fl.
search for 7.25 and youll see the clutches. the discs would likely have to be purchased new as that size spline isnt common like the chevy and ford etc...
