chaser 1jz to 89.5 wire!!
ommpah_lummpah
da gnome
Sep 19, 2007
4
charlotte
hey had a question on the 1jz chaser engine.
i found a few sites that show 1jz supra wires and colors, found 1 that had the chaser diagram but did not work. question is does any body know a good site that shows wire by wire connections? or know a good place i can just send my harness off to, to get extended and fit for my mk3
thanks
jason
Sep 10, 2007
482
Virginia
pm Dr Tweak about the custom harness, he can make you one out of your stock MK3 harness, and a 1jz donor harness for muuuuuuch cheaper than 935 motorsports sells theirs (no donor harnesses necessary from 935 tho. i think?)
good luck
ommpah_lummpah
da gnome
Sep 19, 2007
4
charlotte
honestly i do not know what year chaser, i know it looks like this one http://www.1jz.com/main.html on the home page. It has the vent tube going to the intake y pipe, the ecu has a flying lead and 4 ecu plugs. I found a site that has the engine types and you could tell from the vent tube but i cant find it now =/.
and ill deff get up with that guy that can make me a harness, if not might try to get supra harness and ecu.
thanks for reply's
jason
aphxero
787
Seattle, WA
The easiest way to tell 81 and 90 motor is...
jzx81 has the hot pipe facing foreward at 45 deg angle like jza70.
jzx90 has the hot pipe facing straight out the side like towards the right fender. To the best of my knowledge it's the only 1j with this hot pipe.
And obviously they are the only two that come front sump. And all of them have traction control.
Do you still have the engine mounts? Wanna sell them?
ommpah_lummpah
da gnome
Sep 19, 2007
4
charlotte
ah ok thanks :) . its the jzx81 motor that is the picture i seen, has the vent tube running to the Y piece.
sorry dont have the motor mounts, i used the stock 89 ones because it did not come with them lol. i do have the front sump oil pan tho.
