charged battery, no power!
corewitz
53
Omaha NE
hey all, i think there might be a short in the wiring somewhere, i have perfect voltage at the battery, brand new terminals, with my test light i can touch around the car and i get a perfect ground, but i have no power what so ever, none to fuses, none to inside, nothing. What are some things to check?
mkiiSupraMan18
Needs a new username...
United States
The little (white?) wire coming off of the fuse box. Mine was loose when I put my engine in and I was freaking out thinking my wiring harness was bad, I did something wrong w/ the swap... something major.
Dad wiggled that wire and it turned out to be a bad connection at the terminal. I know with it off, you wont get any power to the interior. :icon_bigg
HTH
isnms
United States of America
Oklahoma
i80.photobucket.com
Small wire attached to positive terminal. Runs down under the fuse box.
FL 2.0L - Headlight relay. Main fusible link - Universal Fusible Link 14 gauge at AutoZone
robbo185
693
Chicago
HTH
yup mine completly fell outta the crimp...i had no idea what it was and was freaking out....it was that
