changing belt/throttle cable
ive done some searchs and still nothing accuarte enough to get the job done.
i need to know what and where to loosen to change the serpentine belt.
and if anybody has any suggestion to changing the throttle cable advice would be helpful!!!
88
1jz swap
no ps/ ac
S.A. supra
2,405
Buda, Texas
88
1jz swap
no ps/ ac
Just Take a wrench to the pulley in the middle. Turn it towards the battery. It help if you have a long wrench for more leverage. with the other hand remove the belt from the p/s pulley, and release the wrench. Just saw that you dont have P/s or A/C It should still be the same the pulley in the middle is spring loaded Thats what keeps the tension on the belt.
