Made a mistake in the passenger name on your Air Canada reservation? Don’t worry—just call
+1 (866) 228-4206 for immediate help.
+1 (866) 228-4206 is your direct hotline for passenger name changes, edits, and spelling corrections on any Air Canada ticket. Whether it’s a missing letter, a swapped name, or a legal name change—support is just one call away.
Fast Name Fix? Call
Don’t wait—Air Canada requires name corrections to be made before check-in. For fastest service, dial
+1 (866) 228-4206 and talk to a live agent right now.
You can’t change the name to a different person. Still unsure? Ask the agent at
+1 (866) 228-4206.
+1 (866) 228-4206.
+1 (866) 228-4206 for urgent updates. Same-day fixes may be possible if handled early.
+1 (866) 228-4206.
+1 (866) 228-4206, you're connected to real Air Canada name change experts, available 24/7. Skip the confusion and speak to someone who can help right away.
+1 (866) 228-4206 to make your edits today.
+1 (866) 228-4206.
You can fix typos, add initials, or make legal updates—but you cannot transfer the ticket to someone else. Agents at
+1 (866) 228-4206 will walk you through the requirements, check for any fees, and get it done fast.
Fast Name Fix? Call
+1 (866) 228-4206
What Can Be Changed?
Air Canada permits minor name corrections, such as:- First or last name typo
- Adding or fixing middle initials
- Legal name updates (e.g., after marriage)
Confirm your case now at+1 (866) 228-4206.
Can You Replace the Passenger?
No. Air Canada does not allow full passenger transfers.
ID or Documents May Be Required
Depending on the correction, you may need to send identification, like a passport or marriage certificate. To find out exactly what’s needed, call
Time-Sensitive? Don’t Wait!
Flights departing soon? Act now by calling
Correction Fees Apply?
Some changes are free, while others may come with a fee based on your fare class. For an accurate quote, contact
Live Experts—No Robots
When you dial
Works for Any Ticket Class
Economy, Business, or First Class—name updates are handled the same. Just call
Summary: change passanger name on Air Canada flight reservation
To correct or change a name on your Air Canada reservation, immediately call
