car wont start! need help
suprafanatic
1,607
Greenwood, IN
so now that it has been getting colder out side my car doesnt want to start.. like if the car sits all night, i go out in the morning to start it it dosent crank or anything, but the battery is still good, all the power stuff works,, and i have to turn the key about 10 times before it starts to crank, then finaly it will start.. whats wrong with it??
NeatOman
Never know enough!
Oct 5, 2006
233
Addison, IL
I had the same problem... have you touched the throttle? When i got mine from the junk yard (1200) i replaced all the hoses and couldn't figure out what was wrong.. untill i started playing with the idle flow screw (witch you should NEVER TOUCH, unless someone has done it for you). I remember the guy at the junkyard playing with it so i just started all the way in then did half turns wile i cranked it for 3-5 sec... got it to turn on after 4.5 turns but it idled to high so i took it down a turn.
Or it could be an intake leak or week CPS signal.. does you're tech needle bounce wile you try to start it?
Edit: Every time the weather change allot or i let it sit for two days it would do that until i started playing with that screw some more, i got it to start when ever now... but my idle is high ~800, im sure i have other problems.
87mgte
87 Turbo Targa
Sep 9, 2007
536
Sequim
NeatOman said:
...but my idle is high ~800, im sure i have other problems.
off topic, but how low is our idle normally supposed to be? mine usually idles at 800... is that bad?
suprafanatic
1,607
Greenwood, IN
ok well heres another thing.. didnt start doing it til it was cold.. also my car has always taken like 2-4 times cranking before it will ever start.. whats up with that? also i dont believe the tach bounces. just dead. but stil have power to lights and things.
