Car shakes when revving in park from idle to 1.5
PROJECT N00b
XBL: Mkiii DriFt3r
May 22, 2005
1,660
honolulu, california
i edited this because it made no sense.
problem 1: when in park, car shakes when revved from idle to 1.5, someone point out what seems to be the probem please. dad says bushings are in need of replacing.
problem 2: driver side door hinge has snapped/broken off, after looking at the damage i was hoping i wouldnt have to remove the panel and stick my hand inside the door to screw it in, but it seems i have to is there an easier way.
problem 3: a rock hit the roof when i went through an underpass, and there is now a dent and paint has been chipped off, it is starting to rain here in my area and i wanted to know if there is anything i can put on it to prevent rust from forming.
johnathan1
Supra =
Aug 19, 2005
5,056
1. Not sure, when did you last replace plugs/wires, etc? Could be a vac leak...Any strange noises?
2. Yes, you will have to remove the door panel to get to the hinge bolts.
3. Put some touch-up paint from Autozone that matches your car on it, and keep your eye on it.
Hope I helped ;).
PROJECT N00b
XBL: Mkiii DriFt3r
May 22, 2005
1,660
thanks buddy. more questions.
problem 4: the front fender is warped and faded...am i better just getting a new one from the junk yard? or what.
problem 5: the interior is kinda shitty...meaning the vinyl sun visors are warping as well (starting to "shrink")...so should i go to the jy for these parts too, or buy it somewhere else.
johnathan1
Supra =
Aug 19, 2005
5,056
4. If you can find a fender in good shape replace it, you may even be able to find one in the same color!
5. I have the same problem with my visors, I am guessing it is pretty common, in fact the vanity mirror is starting to fall out of it :(. If you can find some at a junkyard that are in good shape (unlikely), then replace them. The only other option is to either buy new from Toyota ($170 EACH IIRC), or have them re-covered.
