car is burning oil on start up?
suprafanatic
1,607
Greenwood, IN
SO we found the turbo to be the smoking problem.. i got a stock ct turbo and took mine off. i found the white residue on the manifold and down pipe. i put the stock ct on and the car stopped smoking. However, i think this stock ct is also on its way out. after i got home from the meet i noticed alittle smoke coming out after i sat and let it run for a min. :(
grimreaper
2,180
Dallas
wth i thought these turbos were the latest and greatest compared to the sp series?!
you said the manifold had residue... the exhaust manifold?
T701jz
3M ENGINEER - R.&.D
Jul 23, 2005
657
Santa Clarita Ca.
It could be… Did it come with a flange also? Usually the flange that came with it is restricted so it did not matter what size the in feed line you have.
CajunKenny
PULL MY FINGER. PLEASE!
Nov 15, 2007
3,255
Washington
HA! So much for it being the valve stem seals! :biglaugh: ;)
Hold old and/or miles on that turbo?
dumbo
1,913
Albera, Too Far North
It's still smoking. Are you certain this turbo is screwed too? Odd coincendence.
As for the old turbo, was the drain in good shape, and unrestricted?
dumbo
1,913
Also you said the exhaust manifold had white residue in it? Did the intercooler pipes have oil in them as well? Or else how did the oil get into the exhuast manifold?
enjoi.this
Formerly ChrisC
Aug 18, 2008
674
Kelowna, BC
+3
Not a confirmed diagnosis yet.
T701jz
3M ENGINEER - R.&.D
Jul 23, 2005
657
Santa Clarita Ca.
Have anyone of you guys ever replace a bad seals or just disassembled a turbine housing/compressor and remove the shaft? I'm just puzzled with some of the question.
suprafanatic
1,607
Greenwood, IN
it was deffinitly the turbo that went bad. i took it apart and the rear seal was toast and leaking oil bad. The smoking that is happening now is very seldom and very little smoke. The ct i put on needs rebuilt as well so thats why. getting a T70 this next week!!
