Car acts like a circuit breaker??? WtF?
MDCmotorsports
Indy 500
www.MDCmotorsports.com
So I finally got the new sup together, and got ready to fire it up...
All electronics came on line.... the turbo timer was acting funny.... like it had a relay attached to it... CLICKY CLICKY CLICK CLICK CLICK....
Tried the key... nothing.....
Tried again.... and then NO POWER AT ALL.
No gauges no turbo timer... nill nada.
Let the car sit for about 30 mins, and it came back. Check all fuses. Every thing was fine. Tried starting again, and nothing. No power any where again.
Im thinking this is a ground problem since the battery is relocated by the previous owner to the trunk?
Im lost, any one care to help? :sadwavey:
lagged
1991 1JZ
new rochelle
did it ever run before?
probably have a problem with the starter if the electronics worked before you tried cranking it over.
make sure the battery terminals are tight.
that clicking probably wasnt from the turbo timer, your battery could also be dead.
