cant feel boost
mk3concepts
1j on the way!
Apr 2, 2006
268
Bay Area, Une Town
ok so me and my friend decided to check my valve clearance..we do it..then after we are done..i decided to put 1 of those "speed source" lower intercooler pipe on..and i did..so i take it for a test drive..i push it and the boost gauge is reading but i don't feel anything at all..all i hear is air. the blow off valve works fine..nothing seems to be wrong..i just cant feel boost at all..any suggestions?
oh i already tried searching up so yah =/ no luck
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
Re-tighten all of your clamps, it's probably something simple like you just forgeting to tighten one of them when putting it all back on. That, and make sure your couplers are fully on and that the clamps are clamping down the coupler to the pipe itself.
AGlobalThreat
Acceleration
Apr 4, 2005
991
Santa Clarita
You can spray soapy water over all the clamps/connections and look for bubbles as you rev the engine.
Chances are that if it wasn't leaking before and now it is, it's something that you did. Whether you didn't seal the new ic pipe or you created a new leak on an old pipe, you gotta get out there and find that leak! :)
boost leak...
it will still boost, but the over the top richness will bog it down to the point that it feels like it's not boosting...
