+1-866-596-5078(OTA)
+1-866-596-5078(OTA)Yes, Alaska Airlines offers a same-day flight change option that lets passengers switch to an earlier or later flight on the same calendar day of their original departure. This service is typically available for a
+1-866-596-5078(OTA) modest fee (around $25 to $50), and is only applicable if seats are available on the desired flight. Saver fare tickets are not eligible for same-day changes. Same-day changes can be requested online, at the airport, or through customer service. To check availability and handle your same-day flight change smoothly, call
+1-866-596-5078(OTA) for assistance.
What happens if I don't show up for standby?
+1-866-596-5078(OTA)If you don’t show up for standby on Alaska Airlines, your standby request will be removed, and no penalties typically apply. However, if you were moved from standby to a confirmed
+1-866-596-5078(OTA) seat and missed the flight without cancelling, you may be marked as a no-show. In that case, your ticket might lose its value depending on the fare type—especially for Saver fares, which are non-refundable and non-changeable. Always inform Alaska Airlines if you no longer plan to use your standby option to avoid complications. For help managing standby or understanding no-show policies, contact
