can we use this port for the oil drain???
spoolint78
Representing T.O
T.O
Hey guys
ran into a little problem with my drain line.
it has a slight u shape using the stock drain port.
I was wondering if it were possible to remove the flange from the port under the oil filter housing, and use that as a drain.
Anyone done this before?
i attached a pic of jolliger's ( i believe that;s his sf name) motor.
I'm referring to the little flange under the oil filter housing.
spoolint78
Representing T.O
T.O
lintlars said:
No you cannot I asked the same question to IJ its under pressure
alright, i was wondering that because it looks like it lead to the out on the oil filter adapter
bwest
Drafting, not tailgating
May 18, 2005
502
HippieTown, CA
Did you plug the return on the stock oil pan (return from stock oil cooler)? That could be an idea for a drain.
MDCmotorsports
Indy 500
www.MDCmotorsports.com
To date, I have not found a -10 to 12x1.25 fitting.
Also, you can not use the plate marked "7m" under the oil filter. It is indeed under pressure.
You need to use a 45 deg fitting and a straight fitting instead of two straights.
Or, have a 70-80 deg steel bend made thats -10 comming off the turbo.
cjsupra90
previously chris90na-t
Jun 11, 2005
1,029
Lakeland, FL
And you wont.
to add to that, you wouldn't want to use that small of a drain anyways.
Basically what Jon (MDC) said, or the other option is to open up or drill a hole in the pan and weld a fitting on.
Burntz
Sold the Supra
Apr 20, 2007
582
Nebraska
I think thats the route I'll take. Drain to pan, and tap off of the oil pressure gauge line for the feed?
